Razlaw wrote:
System works but with a few issues.
If you haven't already done so I would power everything off at the mains, then turn things back on one at a time (Videomaster and audiomaster first, then everything else) and see if that makes any difference to the odd behaviours.
I guess depending on the s/w version of your BS3000, some of these behaviours might be bugs in the N.MUSIC / N.RADIO implementation. There were quite a few bug fixes between v2.0 when N.MUSIC was added, and the later v2.12, so if you're on v2.0 that might account for some of the strange behaviours, and in any case all of these software releases will pre-date the BS5 so likely won't have been tested together by B&O.
If the service centre determine that your BS3000 can be upgraded to v3.1, and you proceed with this on the basis of gaining link room functionality, it might be worth trying it again in the configuration you've tried today with the new software to see if anything has improved.
Razlaw wrote:
Also, I can not use the Essence Remote as desired as a short press activates the BS 3000 radio instead of N. Radio and a long press activates CD in BS 3000 instead of N. Music.
Yes, I didn't really consider this, but you will have configured your essence remote to send RADIO and CD IR commands (and then mapped these sources on the BS5), given your BS5 is now looking for N.RADIO and N.MUSIC commands you'd need to change what the essence remote sends, but I don't think any of the IR modes on the essence remote will send N.MUSIC and N.RADIO commands 🙁
Oh well - I'm sorry it hasn't worked out for you but I guess it was worth a try!
Kind Regards,
Martin.
