Razlaw wrote:
Thanks! Is the chip something can be installed easily, or does it require a B and O tech to install?
Officially this is a service tech install. Obviously you could install it yourself with the aid of the service manual but you really ought to take anti-static precautions whilst doing so to avoid any potential damage to either the chip itself or the BS9000, so if you're not familiar with these procedures or lack the necessary equipment then the small cost of getting a service technician to carry out the upgrade could prove a very worthwhile investment in comparison to a much larger repair bill if things go wrong.
The part number I quoted is just the latest software chip for the BS9000mk3. Each different product will have it's own entirely different software.
For the BS3000, N.MUSIC and N.RADIO support was introduced in software v2.0 (subsequently replaced by v2.12 which primarily fixed a number of bugs), then later, link room support (A.OPT 5 and 6) was introduced in v3.1.
The last list I have shows part numbers for both v2.12 and v3.1 chips so it might be that only later models of the BS3000 could be upgraded to v3.1 but you would need to check with a service centre to confirm whether this is the case.
Note that unlike the BS3200, there has never been a MLGW compatibility release for the BS3000 (although that doesn't necessarily mean it wouldn't work with the gateway, just that it hasn't been tested and is not an officially supported setup).
In theory, any BS3000 with N.MUSIC support should work in place of the BS9000 in the setup I outlined previously (BS3000 in A.OPT0, BV in V.OPT2, BS5 set to AudioMaster=no, all speakers connected to BV) but since I don't own a BS3000 I'm unable to confirm this for certain.
Kind Regards,
Martin.
