Beosound 8, what do/ have you done with yours?
Sorry, I was not answering your question but the original one...
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Ralf
Ok - and you were right to!
I was probably too caught up in my own 'problem' ;-(
It would be great though, if anyone has an answer to that/my question
I have been searching for a 30 pins bluetooth receiver for my BS 8 for quite some time but without much success. Below are replies I got from the varoous tech. support teams ;
Reply from WaveJamr
Unfortunately the WaveJamr and similar dongles are not compatible with the BeoSound 8's 30pin connnector - the dock expects a data presence that the dongle does not provide (but attached iDevices do).
Reply from Aluratek
It would depend on the dock that is installed on the stereo. If the dock does not require an active data pin, it should be fine. If the dock requires and active data pin, you probably won't be able to use any audio adapter with it.
Thanks - so it seems, that we won't be able to use one of these small 30 pin connectors ;-(
Using a small BT-dongle with the line-in connection is easy, but rather unhandy because it needs a power supply of some kind.
Answer to the OP:
I use mine with an old iPod Touch, that is online
The brand of the 30 pin Bluetooth adapter I tried was i-wave
Kind of a different matter, but thought its best to ask here than start a new thread.
I have a BeoPlay A8, and I was wandering if there is a way to add it to a Multiroom setup. Is it possible with an Essence? Is it even worth it?
@hadr
I did not try that (yet!), but I don't see why not!
You would - to avoid a double volume control - have to run the Essence box as a fixed line-out into the A8, and control the volume there. This would sort of criple the 'wheely' a bit
You will have to use the BeoMusic app as the main interface - which you would anyway in a multiroom setup.
It is more or less the same, that I do with my Essence (box), which is connected to my old (ML) AudioMaster.
And how did it work out?
It what rubbish
Millemissen wrote:
@hadr
Thank you MM! Might try it out. I'm torn because I like the A8 but it's probably not worth the cost of an Essence just for ML 🙁
