Beosound 8 repair
Good news:
I managed to repair the small ribbon cable myself, so the BS8 is now fully functional !
It was a real bargain. Paid 50€ for it in perfect condition. Only thing I paid extra were new batteries for 3€.
Now I'm happy with my new toy 😁
Thanks again to all who helped.
 Hi Martin,
 I read you manage to repair the cable.  I have got a Beosound 8,  which has the same symptoms. When an iPhone is inserted, it works well. Today I dismantled it and I am pretty sure it is the ribbon cable or the connectors to the ribbon cable that are causing the problems. I would be glad if you could explain how you managed to get rid of the ribbon cable problems.
 Thank you very much,
christoph
BeoIce wrote:
Good news:
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Dear Martin
As Christoph asked, I would also be interested in how you managed to fix the ribbon cable for the keypad. As I have faulty one my self.
I have made a thread of my own in the workbench-section. But hope to here from you, so my unit can get back to life again
/forum/imported-unmapped/beosound-8---broken-20-pin-ribbon-cable
Hi Kristian & Christoph,
in my case I managed to resolder the cable to the connector, but there were only two leads ripped off, not the complete connector.
Dear BeoIce
Thanks for the quick response. I hope somebody else knows where I should search otherwise I will just have to order a couple of different ribbon cables 😁
Hi
I have BS8 ...it is workig..but!
When i charge or play iphone4S orange there is orange LED on BS8.
Must be green ?
Docking part plastic is not 100% ok..do you think it's that problem ?
Anyone have that part for sell ?
Thannks
Did you check the 30pin socket of your iPhone for collected dust particles inside? They like to block the contacts. A toothpick may be your helper.
Hi
yp...i did..in the Beoplay 8 is working perfectly fine.
It's 30 pin connector on BS8 that is faulty an no longer at the B&O in stock.
at least i receive that info..
