Visually balanced means that the visible elements, when viewed from the front, are similar in proportion when an iPad is docked on top. The transom is thick enough, vertically, to look as though it can support the iPad (though the device is really very light), and the speakers are similar in dimension so as not to look "underpowered" when the iPad is placed on top. If any of these elements were much smaller, the iPad would look out of scale.
Another piece of your circular arguments: You're saying that it's visually balanced, because the dimensions of the speakers and bridge doesn't change.
No I'm not. Your imagination is playing too heavily into your interpretation. I'm saying that there are 3 visual elements. Two speakers, one transom. These are all give visual weight in their scale and dimension. The iPad is very large, and similar in scale visually. This is what I'm saying. You can't accuse me of circular logic based on an erroneous interpretation of what I'm saying.
The logic is only nonsensical if you don't understand what words mean. A dock implies a quick attachment. The iPod/iPad demand that their screens be visible, so it's a foregone conclusion that the device will be visible & upright.No, it's circular logic and nonsensical, because you choose to use a descriptor of functionality to define "good design", by claiming that the descriptive word "dock" describes the BS8 very well.
It's a dock! That's what it is! Your entire argument on this point is that it's a speaker set that connects to an iPod which is entirely an invention on your part. It's an iPod dock. Not a stereo where one of the sources could potentially be an iPod. It was conceived that way, designed that way, and operates that way. If you're holding out for a different product, that's fine.
If you think that that's a fallacy, please provide an example of a usable dock that does not follow this paradigm. All iOS devices are either on top of or in front of the chassis. Anything else would be unusable in the paradigm of a dock since remote control is limited to basic navigation and not rich browsing.See above.
Yes, your point was dealt with handily above.
On your final point, your argument would not be correct, though, and would be counter to the stated intention of the designer. While artistic objects inspire multiple interpretations, it is designed to be an iPod/iPad dock with high quality speakers. For a digital music system you move into Sonos/BeoSound 5/Etc. territory where the interface takes on a new paradigm (browsing in your hand instead of locally + the ability to choose from a range of speakers for a range of applications).You're misrepresenting what I say. My point is not at all about moving this into the territory of Sonos and Squeezebox, it's about this thing being a boom box using an iPad/iPhone/iPod as a source. That is the only design brief that makes sense, not "design a dock".
Again, see above. Your interpretation was not the design brief. This is an iPod dock. That's the only way it's discussed. That you can plug another device into it is a value-add to the iPod dock form factor.
I appreciate that you have taken on arguing with me as a pet project, but as my wife can assure you, I do not lose arguments. I will wear you down to a nub and leave you a trembling husk. I will do this even if I'm wrong. Happy New Year!![]()
Hmm, just because you don't give up or change your stance, doesn't mean you don't loose the argument.
You're correct. I win them generally because I'm right. That's especially true here.
