Beosound 8 - picking it up tomorrow!
Henry,
Thanks for your message. I'm not interested in the B and O app - not too impressed myself but I guess with it being new it will take a while for comments to filter back and i guess there will be an update in the future.
£12.99 is a bit steep. What you need to do is download TuneIn radio which has pretty much all the radio stations in the world on!!! Requires an internet connection or 3G to work best! I think the app is 59p!!!
What are you using it with? Ipod or Ipad? And what colour did you get? I am sure it will be an excellent system - we need pictures! 🙂
Thanks Chris. I've discovered tune-in radio and it's this I've had to get working with the BS8 using trial and error. It's working out the difference between "on", "stand by" and "deep sleep" that's been taxing. With an iPod touch docked you then have two devices that have to be in the correct state at the same time for the alarm to work. Being colour blind and the indicator light just a pin *** I can't tell the difference between green, orange and red. What fun.
Must be some daft filter on here that's never heard of a pin pr*ck (my '*' or it will be bleeped out!) of light?
Automatic filter - clearly American English or your first post would not have got through! 😁
I've just seen why😉
I picked mine yesterday on Dec 31st of 2010 AD.
I unwrapped it at home, connected the power cable to the beosound, adjusted the weel, put my iPod touch 1st generation on the dock, started a piece of music (Stairway to heaven) and ... nothing happend.
I started troubleshooting and voilà:
Plugging the cable into the electrical socket nearby in the wall did the job 💡.
Listening to my music and to some radiostations via diverse radio apps is fine (Beoplayer only works with my iPod touch 4th generation). Sound is very good. Stereobase ist a little bit too narrow. But it doesn't matter during breakfast in my kitchen and in other places I want to present sound (and pictures).
The remote control is just the right thing, better than a Beo 4, which does a good job in my living room.
iPoditiv
Does anyone know if the A9 Keyring will work with BS8? What is the RRP of the A9 Keyring and what features would work with it?
The only function you'd get would be to switch it OFF!
I can't wait to see pictures ;-)
