BeoSound 5 Not Supported by Spotify
TWG wrote:
Hmm, it's kind of the same solution that B&O suggested with the Behringer USB-Audiointerface + Google Chromecast but this time it's a perfect solution? How can this be?
The solution above means that the exisitng ML system works as before pressing List ( List List list ) until AAUX selecting that then picking up a smart phone to operate the item connected to the behringer. Be aware that as the Behringer converts from Analogue to digital then the PC/BM5  converts back from digital to analogue the sound is rather poor.
Ok to bring new life to the ML system , but far from ideal, both sound wise and in its clumsy operation. A long way from B&O high ideals!
TWG wrote:
Ok, you can inject a local "AUX" signal to every active speaker but you still need a phone/tablet to control it, you can't control it with B&O remote control and it's only a local source, not available on the ML or NL.
Yes using Active kits you can use a 3rd party source in this way again rather clumsy having to use the B&O remote and then the 3rd party app. Plus the local source then is not used globally.
The solution in the video means that the ML system stays as it is.
Then each room that has the switch works automatically from a 3rd party app and all rooms can be controlled from a single smartphone work independently, play different sources or group from any room (depending on the source). Far superior with a longer shelf life, yes a bit more money, than the B&O proposed solution.
Indeed if you want the best of all B&O worlds you could plug an Essense into the switch in each room. Sound quality through the switch may have a slight compromise, but sorry it is much, much, much better than the Behringer solution which always has struck me as a bodge up. From the start the ML board on the BM5 should have had an analogue input that could have given the sound quality we are used to through ML.
Spotify does not work anymore on beovision avant. It is unbelievable that B&O has only implemented Spotify half heartedly without agreements on service.
do you know if it still works on beovision 11?
It does not work on BV11 either Erm..
That is not how the business model work unfortunately. App providers has no obligations to the platform owners (in this case B&O). And that is regardless if it's Netflix, Spotify, Viaplay etc, etc. App provider take their own decisions with regards to where they want their apps to be and on what platforms. Viaplay for instance decided to remove their app from B&Os old "smart tv platform" since the number of TVs sold was too low in the Nordics, in comparison to the cost of maintaining an app.
I know this for a fact since I'm in that business 😕
You have to choose who you luv more:
Spotify or B&O
I choose B&O
B
Hey everybody,
therefore i think it is important to keep this thread alive, keep calling your dealer or regional manager. Tell them it is unacceptable. If they want they can solve it.
See also: https://community.spotify.com/t5/Idea-Submissions/Bang-amp-Olufsen-Continues-with-the-app-for-B-amp-O-BeoSound5/idc-p/1733334#M52562
I agree, keep sending support requests to B&O as well that you are not satisfied with their solution.
They have the new Spotify code available that Spotify have shared with B&O.
Located in Sweden and have passion for B&O since my years in school. Had the pleasure to be employed by the local B&O dealer in town in the 90th and got an education on the B&O product range at that time (the last fully 2-way integrated products).
Now fascinated about how far ahead B&O was with their Link integrations that you can still use to control and integrate 40 years old products in your smart home.
Prefer the older products since I feel those had a different classic to them and also they were priced/aimed more to the market so that normal people still had a chance to realize their dream and own a B&O product.
Went to my dealer yesterday, and even though they try at their level to find a solution for their customers they don't get any support from B&O itself apart from the three suggested (underachieving and stupid,...) solutions.
here you will see that, compared to BS5 owners, this thread concerning Squeezebox gets more traction.
https://community.spotify.com/t5/Live-Ideas/All-Platforms-Music-Keep-squeezebox-support/idi-p/1737939#comments
At least for Squeezebox owners there seems to be a solution:
