Beosound 5 Encore Wi fi connection issue
I recently installed an epsom wi fi printer, on installing it I made a change on my router security. When switching on the BOS5E obviously it would not connect. Now however when I use it to search for the wi fi it doesnt pick it up. So I have entered the router id and the passwords and it searches for it but still does not pick it up for connection. Anyone have any idea how I can solve this.
Does anyone at all have any ideas please, I am getting BS5E withdrawal symptoms being without it now for 2 days.
Hello there,
Seems as this is a simple case of either router settings which have changed or IP address. Either the printer has turned off UPNP or the printer has the same IP as BS5E. If UPNP is off turn it back on in router settings. If IP address issue change BS5E ip address.
If you are not sure how to change these settings, just contact local dealer with these 2 suggestions.
Hi applemac,
" I made a change on my router security "
Could you be more specific - what did you change?
Be sure that DLNA is enabled in the router settings, and that the (DLNA)server on the network is running.
N.B. Two devices with the same ip-adress on the same network is not possible.
Seems to me to be a port-issue.
Do you have a person with network-skills in your neighborhood?
Hi I made a mistake and change the security setting to connect the printer when I did not need to, however following your advice and switching of the security of the router allowed the BSE5 to connect to the router viua wi fi. However I cant leave the wi fi on without security.
Koko,
thanks you advice actually solved my problem, firstly I turn off the security on my router this allowed the BOS5E to connect to the router, after it obtainned a IP address etc I then switched the security setting back on my router. Turned off the BOS5E and turned it back on and it still connects.
Thanks for all the help
Actually, the same issue I have also faced with my canon printer that time
Want an awesome looking jaw-dropping website? UAE Website development provides
Great answer. We provide professional
