rednik wrote:
Like I say I must be odd, or maybe I just don't buy into this thing where a system must do airplay, even if there's no real benefit to it, just because some other manufacturer has done it.
I've explained the benefits.
One key advantage of supporting AirPlay is that you can use your iPhone or iPad (or computer) as a remote. You can then assign your music to stream to multiple AirPlay devices, without anything being connected. For example, the Zeppelin has, effectively, the Airport Express built in to it. This means you could walk from room to room, or from house to outdoors, listening to the same streamed track from multiple AirPlay devices.
You can even use AirPlay to stream audio to your iPhone from your computer, exactly what you have asked for above!
AirPlay support enables a device to tap in to an iTunes library which, as people have said, doesn't support the UPnP standards, so can't be accessed from something like the Beosound 5, without another media server on top (Twonky or similar).
There are advantages. Just as you can't see them, doesn't mean they don't exist. And for a £2500 device, I expect it to support as many standards as possible....including "closed" licensed standards! Frankly, I don't care if some people don't want it on their system, if B&W can license it on a £400 device, I'm sure B&O could.
