Beosound 5 encore
Hi does anyone know what format an external hard drive needs to be to plug into the beosound 5 encore. My pc is a mac
DLNA
You can try Twonky Media on your mac or similar
No what I want to fo is attach a hard drive directly to the beosound. But ive formatted the drive and it does not show on the beosound 5 rncore
Hi Paul,Ill try and help as much as my memory allows from all that time ago when i had one. Firstly, i remember having a WD network drive with Twonky, but i am sure that i also attached a HDD to one as well.From memory you have to get the BS5Encore to find / recognise the driveIt’s been years, but i think you have to press > > GO and there you can choose one of the options there in the service menuTry that and hope it works.
Paul,I use(d) a 256GB thumb drive for my BS5E. I think I formatted it as FAT32.If you want to use a large capacity hard drive, try exFAT.Hi does anyone know what format an external hard drive needs to be to plug into the beosound 5 encore. My pc is a mac Current b and o Products beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
FAT32 should be fine. I use my BeoSound5 Encore with a Mac as well, and that has always worked for me.
Ok i will try the fat32 cheers for the advice appreciate it
Hi I have tried Fat32 and msdos fat but drive will not show on the boesound 5 encore, any idea why not?
Paul, a few thoughts:- Does the external drive have its own power supply, or is it powered by the USB socket? Some external HDDs require more power than the BS5E’s USB socket can provide. This shouldn’t be a problem with an SSD.- If it is a HDD, is it actually spinning?- What is the total capacity of the drive?- Have you installed only 1 partition on it? More than one partition may confuse the BS5E. - Have you connected it via a USB hub? If so, try connecting it directly.- How much music (GB) do you have on the drive? The larger the music library, the longer it takes the BS5E to load it.
