Beosound 5 App
I have had exactly the same thought about the A3.
If it is free, I also lost $50.00.  But it is still worth it.
Wish list:
1. Ability to show full screen album art for album playing now...like BS5 does
2. Ability to shut off system from app.
I downloaded a 1000x1000 hi res art for one album to see how it would look , but have to wait for THAT album to scroll through in order to confirm improvement (see point #1)
Barry
I haven't been able to get mine to load beyond "C" in albums. Obviously, they still have some bugs to work out. Perhaps this is why it went from being $50 to free.
I have tried to use it this morning but it can't locate my BeoSound/Master 5 at all....
PS. The app is only free for 48 hours.... You will then need to pay for it.
Do you have your Beosound 5 set to music server on?
HI everybody can you tell me if this application is available for Beosound 5 encore ? Thanks for your answers.  Pascal
I believe the information page for the app says it does not work with the Encore.
Yep... definately 'server on'...
The free trial was/is meant for dealers to try it out.
I have absolutely no problem with all my albums loading, but then aagin I have really made sure my tags are ideal/correct and album art is both embedded and in the cvr folder (possible with Bliss Tagger).
Even my Love Never Dies 1000x 1000 hi res art does show beautifully on the Ipad.  Will be upping the rez specs for art starting now.
LUV IT!
Barry
I contemplated downloading last night. .
Raz what did you find out about the whole home set up?
Does it work through/with MLGW and RadioRa2?
That looked very cool!
The app looks pretty good if it works without drop outs. .
what are you all using for a router?
