Hi there,
i am searching for solution for my problem with the volume control on my beosound 4.
The volume control on the unit is locked / does not work. I can hear the reel switching every step by turning it, but the volume is locked / fixed bei Volume XX.
I didn´t found any information in the user manual or in forum or internet how exactly to reset the unit to the factory settings or hw to fix this problem.
There is no option to reset it in the menue of the unit.
There is no reset button on the unit.
Any idea?
HELP!!
Regards Vlad
