Hi folks
My Beomaster 5000 (bought new in 1984!) and CD 50 (c1986) have finally died, and I've just bought myself a new Beosound 4. About 12 years ago the baffles in my RL60 speakers fell to bits, and I bought a couple of Beolab 6000 speakers - incidentally at the time the dealers told me I couldn't drive them from a Beomaster 5000, but I checked the outputs from the phono sockets and contacted B&O in Denmark, who confirmed it would work. The sound quality was brilliant, and I used the old RL60s (with the baffles removed) as rear speakers to give a really rich sound.
So, now I have a Beosound 4 driving my two old Beolab 6000s via my existing phono cabes via an adaptor cable I have made up terminating in a 5-pin DIN plug for the Powerlink socket. I also bought a pair of Beolab 4s to use as rear speakers, driven from the second Powerlink socket so I can disconnect them easily. I have also built myself a fader control fro the Beolab 4s, but that's another story!
It all works, and DAB radio is brilliant. BUT - I am disappointed in the sound quality particularly on CD (haven't tried the SD card yet - one step at a time). I have lost the really high frequencies which give the real feeling of presence, and which my old system gave me. It all sounds a bit muffled and boring, the quality being what I could have got from a £300 setup. The bass is a bit lacking, but that would be me missing my old RL60s, and I'm not quite ready to go for a subwoofer. The main speakers are the same, the cabling (apart from the adaptors) is the same, so is the problem with my Beosound 4? The threads I have looked at would indicate that the Beosound 4 gives high quality sound particularly on CD.
So - should I upgrade to proper Powerlink cables, or indeed Sounds Heavenly cables, or do I need talk again to my dealer about my particular Beosound 4? Could it be out of specification, or am I expecting too much? Any other suggestions would be really appreciated. Incidentally, I have run trials both with and without the Beolab 4s in case I was getting a capacitance effect with the additional cabling.
Many thanks
