Beosound 4 recording
I wanted to record a radio programme while I was out today but my 2008 unit wont give me PLAY TIMER options - is it possible to update its software without visiting a service centre ?
no you must visit your service center.
If you have old hardware ( I believe 2008 is)  you will need a hardware upgrade.
Newer Beosound 4 can be updated without opening.
The lastest firmaware supports bigger than 2Gb  SDCards as well!
Ralf
Thank you for that advice, Paul
What is the latest firmware?
Hi i let my dealer update my Beosound 4 in december 2016:
Very important is the codec which supports SD cards >  2Gb with version 1.31c and higher only.
Ralf
AP 2.92I
OS 16.30A
APBOOT 1.001
IOP 22.00A
FM 1.001
Display 3o
Codec 1.31c
XPFEP 1.10A
