BeoSound 4 not working with 8GB SD card
I have just purchased a 8GB SD card for my BeoSound 4. It is not accepting the card. My old 4GB is working very well.
Is there any max. memory limit ???
Thanks ahead !
Regards
Torben
Hi Torben,
I do not think an 8GB SD card is supported by the BeoSound 4.
Thanks !!! Is this the same for BeoSound 3 and 2 ???
An 8GB SD card will certainly not work on the BeoSound 2. I am not very updated with the BeoSound 3, but I doubt this will work with an 8GB SD card either.
BeoSound 2 (firmware 1.1.0.11 or higher - SW 2.50) and BeoSound 4 can handle
SD cards with a capacity of up to 2 Gb.
