Hi Forum
I have a BeoSound 35 in my setup. Most of the time I used to control volume and skip tracks with the beloved Beo4 remote, because the BS35 actually have an IR-eye integrated (though there is not much documentation about it).
The control from the Beo4 has suddenly stopped working!
I have recently installed a firmware upgrade of the BS35 to version 1.27.47106
But I cannot tell if the firmware upgrade causes the IR-eye in the BS35 not to work, of if it happened just before the upgrade.
- I have ensured to verify that the Beo4 works (I can see the LEDs blinking when testing via a camera phone).
- I have ensured to point the Beo4 to the BS35, and set the A.option to 1
- I have verified that the Beo4 actually works, by testing it on my BS9000, which reacts accordingly.
- I have not touched the BS35 at all. It is mounted on the table stand, and is located on top of a bookshelf. I only control the BS35 remotely from the App and Beo4.
Are there other users of the BS35 with the IR that have a similar experience/issue?
Is it a common issue for the BS35 that the IR-eye fails?
I have never before had any IR-issues with my legacy B&O systems (BS9000 and BS Overture).
