Let's hope so. In my situation the BeoSetup app is way to slow to be usable for starting stopping timers. You should be able to start and stop the timer from the BeoMusic app.Yeah I have the update to my Essence too! It says you can activate timers etc. from the Beomusic app. So perhaps there's an update coming for that too. I heard Beolink and Beomusic apps were merging. BV11-46, Beoplay A2, H3 ANC, Beo 4, Beoplay S8, Beosound Essence MkII
BeoSound 35
In the next update, BeoSetup is "integrated" in BeoMusic Login to view imageLet's hope so. In my situation the BeoSetup app is way to slow to be usable for starting stopping timers. You should be able to start and stop the timer from the BeoMusic app. - Flere smile and enjoy the moment
Hi! I love its sound! It's very well balanced, present, with realtolife voices, full bodied bass, clear highs. Just what I expected. What other opinions have you received?Hi there How do you rate the sound from the BS35? I hear different opinions BLGW - Rekindling the love of ML
yes this can be disabled. Had to do so when I set up the BS35 with my LG TV through BeoHub.
Wonder what the second screen (below) is for ?
I tried to tilt the BS35 back and forth to see if the display changes, but nothing happened...😮
I asked about that at my local B&O store. According to them, it's not a display but it's the infrared receiver for remote control. Quite large at that.
Thank you for your post, but it really looks like a display...
[Edit] it seems your dealer is right
Difficult to read, but it's written "window for sensors and antennas"
