Hello,
I have been looking into cloning my HDD as a precautionary measure. I’ve found a cloning device but it was for SATA drives and the one in BeoSound 3200 is IDE. However with IDE to SATA converters I managed to clone the drive perfectly yesterday.
However, when I fit the cloned drive into BeoSound 3200 and try to play it it displays “HDD LOCK”.
I then looked into more detail of the drives. The original (and cloned) has 5 virtual drives on the HDD. One for each color and a fifth one. The clone has the correct serial number for these virtual drives. (I could look at the drive that would mount in WinXP. Could even play the music files but as I didn’t have the right codecs it sounded awful).
Long story short, I suspect the music hardware looks at the hardware serial of the drive and will only play if it matches. This is probably why my clone won’t play.
As it looks we will need to find a way to change the hardware serial of the IDE hard disk to the one that was originally in the caddy.
Does anyone know how to do this?
If so I suspect any BeoSound 3200 can use any clone drive out there once the serial has been changed to the original one.
If anyone knows how to change the hardware serial please share.
Regards BeoMedia
