BeoSound 3200 pin code issue need help!!! TheRed LED not blinking!!
issue with the power supply ?? Can you be more specific please.
There is a small fuse that causes this kind af failure if blown.
It is not one of those large psysical glass ones, though.
Small fuse?? its sounds like a super fast fix. Do you by any chance tell me the part number.
I hope its not too expensive part anyway.
I can call bang olufsen tech support to order that fuse
HI Casper,
If by any chance you do not know the part number, may be you know the Type or Description of the power supply fuse.
Please reply with some info if you can.
Thank you so much for all your help
Hi Beobuddy,
I have a error message on my Beosound 3200. How you  can  fix that?
19: TP module HW error APOS   My BS 3200 not responding. only load button works.
Can you  fix that?
Hi Beobuddy,
I have a same error message on my Beosound 3200. How you  can  fix that?
Can you  fix that?
I just found out that I do have an error in testing mode on my BS 3200
19: TP module HW error APOS  I think its a microprocessor issue??
Is it possible to fix?
a looooot  of BS 2300 and 3000 have the same issue.
i have one BS 3000 at home like that.
so..anyone have fix these error without B&O service ??
