Beosound 3200 and AirPlay
I stopped using airport express on my BS9000 via Aux because of the poor sound quality.
Yes it worked, it's nice to have an Idevice in hand and play sound via your B & O speakers but the sound is not good.
I'm talking about Spotify or Itunes here not better quality music if that exists.
And you have to set the volume way up compared to a cd listening.
A DAC or Playmaker must be considered. Just my opinion based on my experience (BS9000 / beolab 8000 and airport express).
Why did they discontinue the Playmaker?
Sound quality wise is a bluetooth adapter worse than an AE?
Cheers
Nigel
..... because they thought the Essence was a superior solution
I think most us would now agree that both have a role (with overlaps)
Agree
Playmaker was a simple product that integrated well with existing ML audio masters to distribute high quality streaming music throughout the home
Agree
+1
I love my Playmaker.
But the Playmaker was marketed as a standalone solution - and ML does not matter for future products.
For the company there was too much overlap.
So discontinuing it was obvious - even if a lot of 'the old costumers' can/could benefit from it.
Hey Beogreg,
I think you may have had a problem with your AE set up. I use mine on three different systems and volume is the same as other inputs whether I stream from my PC, Mac, iPhone or iPad (usually use iTunes on Mac with lossless and mac quality Spotify from iPad). I just set iDevice/PC output to max and control volume via Beo4.
Thank you  - I have purchased an AE, setup was really simple and the sound is very good. I am just really pleased I can now use my B&O system to stream music to.
Glad you have found a solution to your streaming question.
Enjoy this new addition to your system. 🙂
Opman
