BeoSound 3200 & BeoMaster 7000 on the same MasterLink
I would like to connect a BeoSound 3200 plus a BeoPort in the main room and a BeoMaster 7000 plus a BeoVision MX5500 in a link room (through a BeoLink Converter) to a same MasterLink. Is it possible ? If yes, then how should I program the "Options" ?
Thanks,
Tibor
Hi Tibor🙂
I might be wrong but, I don't think you can have two audio  masters on one system. If you press CD on the remote, it wouldn't know whether you mean the 3200CD or the 7000CD
If I'm wrong, I'm sure someone will be along shortly to correct me.
Andy T.
It's not possible to link BS3200 to BM7000. but you can connect MX5500 to BS3200 with a beolink video converter. Then between the MX and the converter you place a Y connection. use a Datalink cable where you remove the Data pin ( it's pin 1 or 7 just remove both of them one is data ground and the other is data), from the Y to AUX in on BM7000.
Then you just turn BM7000 on AUX and control the BS3200 with the MX5500 (AV + Radio). thy all has to be in option 1,
