Beosound 3000 wont start.
Joker22 wrote:
Cant do anything, execpt enter test mode
Ok, sounds like a dead processor module then. Not easy to fix, you need to find a replacement unfortunately.
/Jacob
Thanks..
Do you have any ideas were to find a modul.
Morten
Joker22 wrote:
Thanks..
Morten
Nope, you need to find another 3000 unit, that might be broken in other ways, and then swap the module.
It is also possible you use the processor modules from Beovision 7-32, I have used one of those before, it is a bit more complex, because you need to find a module from the TV that has pincode disabled, and then you need to swap the EEPROM with the 3000 software from your unit to the new unit. This is also a chance, because it could be your 3000's eeprom that is dead, but it is more likely to be the surrounding module that is dead.
The best solution is to find another defect 3000 with a working processor. Just remember that you need to have the pin code for the defect unit also.
/Jacob
Just repaired a dead 3000 by fitting the processor from a Beovision 7 I scrapped last week, working great now thanks for the info
Stuart
Stuart
Hi Lee, I got a issue abit same like this, this morning when I am power on the beosound 3000, it's just work 5 seconds and suddenly switch off and the screen show nothing, after that totally can't power on, even can't show the red light, pls give me some advice. Thanks alot
