Beosound 3000 wont start.
Hi all..
My beosound 3000 wont start playing.. cd/radio.
The standby light is on as normal.
The doors open like normal.
The "tray" open so i can insert a cd, and close fine again..
But when i press cd, nothing happen, not even on the remote.. or any other button
I have change OPTION  A.OPT to 1.. the red light flash 1 time, but nothing happens..
Any ideas ?
Best regards
Morten
jap...very very common problem of these devices!
Hi..
Maby i ask stupid..
But if the laser i gone, will the radio not work?
The Radio doesn't work either?!
Okay.. perhaps a different approach.  Your button pad may be faulty...
What happens if you press Radio on the remote?
Nothing,  not any buttons work on the remote eighter.
I can press sound 0 2 5 8 and get in test mode.
In test mode, i can test button pad, all works, and the remote also works..
In TM 31, factory settings, i get message TM error
When i leave test mode, nothing works..
Best regards
Morten
Well, that's the basics covered then!  All I can think of is that the microprocessor is faulty, but I've kind of reached my limit here as I'm not an engineer.
Im also totally lost..
Joker22 wrote:
Hi all..
Any ideas ?
Best regards
Morten
I have seen 2 3000 units with defective processors, it can behave very weird when this is happening, but it is funny that you can enter service mode and so on.
Can the radio tune stations, can you delete/store new stations ?
/Jacob
Hej jakob..
No, cant turn on the radio, so cant tune stations..
Cant do anything, execpt enter test mode
