Members, today I picked up a preowned beosound 3000 & beolab 2500 speakers. I'd like to know if there's a way to do a wipe/reset of all the settings from the previous owner?
Beosound 3000 reset?
TestMode 31 will clear all radio/cd/timer/sound settings
/Weebyx
To enter testmode, within 30 seconds after connecting power to the unit, press SOUND 0 2 5 8 on the keyboard with no more than 2 seconds between each press.
Then just press 31, and the display will show DEFAULT TM ERROR, then just press standby, and all should be cleared.
/Weebyx
I tried test mode 31 and I received an error. Is #31 for the 9000 only?
No, took the instructions from the bs3000 service manual .. What error did you get ? If all is well, the display will show DEFAULT TM ERROR, if something went wrong, it will say TM ERROR.
/weebyx
Mine says TM error in nr 31..
Whats i wrong?
mine says the same, anyone can help?
There shouldn't be a need to reset it - just delete the station presets, enter your own, and adjust the bass/treble/balance/turn-on volume level. The user manual is onsite for silver and gold members if you need it.
Resetting is not the problem, the problem is that we both have a TM ERROR, what I've read is that the eeprom is bad and/or the processor, nothing to reset anymore, its a goner or it will be a costly repair.... 🙁😭😠
Just ignore this error, if your 3000 is working, you can store/delete channels/set timers/tune stations and play a CD, then why care about this ?
The processor is NOT faulty, I have seen a lot of these 3000's they almost never give correct feedback for the RESET Testmode.
Don't worry about it :)
/Jacob
