Beosound 3000 problem
LIST and STANDBY on Beo4 LIST to OPTION
LIST to A.OPT 1 GO
Ulf
Am away at moment but will try when I get back. Not sure why it has suddenly stopped responding to the remote - and particularly why I cannot use the buttons - but I do have a Beo5 that seems to send random ir's around the house so not sure if that has something to do with it.
Will let you know when I have tried.
Back at home. 3000 still not responding to remote even after taking advice above. Remote works fine with everything else. Buttons now working but I do not know why!! Happened after I reset the date.
Any more bright ideas out there?
Hello johnheartfield,
did you find a solution to your problem?
My Beosound 3000 showes today the same problem. Cannot change volume and the sound button shows "Use TV".
Can anybody help?
Problem seems to be catching!! I "solved" the problem but do not really understand how - did it under the influence of red wine.
As I recall there seem to be two phases. Firstly I pressed "sound" "0" "store" (I think) on the 3000. This brought all the buttons back into use but did not help with the remote. I then used the "option " advice suggested in this thread to get the remote working..
I am sure Peter or one of the more techy guys can give you chapter and verse.
