Beosound 3000 - no sound
Not a silly idea at all. Some don't know about the mute function but I think in this case Leo will. This on does seem a bit odd though.
Good luck Leo as you've only just got all of this set-up with you TV!
If you disconnect the Masterlink cable and have the speakers directly connected to the Beosound what happens?
Dave
There is no issue with the mute-button. I have tried both in masterlink-mode and in powerlink-mode. None of them gives sound. The connected speakers turn on when the unit is turned on.
This one is really making me scratch my head, since there are no error codes either. And yes, I have become the master off power-cycling :P
I am really concidering to bite the pillow on this one, and simply have it serviced at B&O. 😭
leosgonewild wrote:
I am really concidering to bite the pillow on this one...
Funny terminology.
Well, I know I will have this feeling after..
https://www.youtube.com/watch?v=_KqqRPvM_Sw
Update: it was the cpuboard(?) having a problem with the input selection.
Repair cost including general service will be 176€. So I think I got away fairly cheap.
Reminds me of the Jeremy Thorpe scandal in the UK 🙂
