good Morning,
is there a Function in the BS3000, where i can permanently mute the Powerlink? my Setup:
BS3000 w/ beolab 2500 via powerlink, beolab 2000 via Masterlink!
after renovation I plugged system in and it worked. I only needed to reset the timer in order to have the beolab 2000 waking ne up in the morning with CD. This works, however even when switching on, no Sound from lab 2500. timer deleted, no Sound! Masterlink works......
Reset via pulling Plug, no Sound! 😱
Went downstairs! Plugged lab3000 on, Display says cd or radio, however "--" for Sound level...... No Sound.....
i am lost what Else to try!?
thanks for any help!!!!
best regards, markus
