I'm sure these questions have been asked many times, but I can't seem to find definitive answers.
I have a BeoSound 3000 with BL (active) 6000 speakers and would like to add a couple of Beovox passive speakers to the rear of the same room.
I can do this with my BeoCenter 9500 as it has both Powerlink and passive speaker ports (and sounds great!) but, of course, the Beosound doesn't have passive ports.
I've asked my B&O dealer and they say I need the Beolink Passive, which I can see does the job but is really designed for a separate room and controlled with an IR eye. However, what is confusing is that the MCL2P and ML/MCL also seem to suit the bill. Bearing in mind I don't need independent remote control of the passive speakers, (and the Beolink can be sited next to the BeoSound) which BeoLink converter is most apt for passive speakers in the same room as the active speakers?
One other question if you don't mind. Is it possible to connect a Beogram 4500 turnatable (or any other turntable with an integrated RIAA amp) to a Beocenter 9500 or 8500? Is there a cable available that, in effect, cuts out the amp signal from the deck, or does the deck have to be dismantled and the RIAA amp disconnected? Is there a simple workaround? I have most Beolink remotes but haven't found an option.
Thanking you in advance.
Rob
