It should go to the termal sensor.
anyone knows how to install the built in sensor, and what kind of sensor it used.
cheers
If the original battery is dead, i suggest you strip it and just replace the cell.
You'll have a precise part number printed on the original cells and reuse the connectors and sensors.
It's what i usually do for Beo6 remote batteries.
Unfortunately, I don't have the original one, that's the problem.
anyone there have a spare dead battery for BS3, I would like to reuse
the female plug with wires & the sensor and I will pay for that.
Cheers!
here on German Ebay for only 30 € for tinkerer ....
good luck 🙂
Hi, this is the BS3 battery connection schematic. The NTC sensor temperature is 8,5Kohm at 27°C. It is not necessary to have the female connector. Insert insulated wire into the three pins of the male connector and stop them with blu-tack or hot glue.
Internal view
