BeoSound 3 - short loud hiss sound between MP3 tracks
Hello - I have just bought a new BeoSound 3. I am trying to playback MP3 songs from 2 different SD cards and I have the same problem with both of them:
Between every other song I get a loud but short hiss before the song starts. Is this something you have experienced and what might be the solution?
The MP3 songs are in 2 folders in the root of the card and encoding comply with the guidelines of the user manual.
PS: Why can the BeoSound 3 not handle SD cards of larger sizes than 2GB? (I've tried an 8GB that didn't work with the BeoSound 3).
BeoSound 3 only supports SD cards up to 2 GB in size from SanDisk. BeoSound 4 (mk. II) supports SD cards up 16 GB.
I have the Beosound 4 (mk. II) using different SanDisk SD cards at 2 GB / 4 GB / 8 GB without any hiss. I am using my PC and Windows Media Player with 192 Kbps for "recording" the tracks.
Try to format the card and then save some new songs into a folder from your PC.
I've tried formatting several times and added different songs and it still doesn't work. The SD card I use is from SanDisk and is 2GB a higher speed version of 15 MB/s called "Ultra II" but don't see why a faster card should cause any issues?
I have also tried with a non-SanDisk SD card of conventional speed and 512MB but not of the brand SanDisk and I get the same hiss sound.
I can convert new MP3 songs but if the product is soo sensitive to formats etc (and the songs I have added to the SD cards comply with the specifications) it is an odd product. I might have a faulty unit - what a shame.
Well - You might have a faulty unit - I dont think this hiss is normal on Beosound 3. On Beosound 4 i dont have any noise of any kind when playing SD card.
It must be other members who has Beosound 3 and can help you! Or try the Bang & Olufsen homepage:
Sorry for being obvious, but do these MP3's sound OK on other kit than your BS3?
Hi, yes they are fine on other units. I've simply dragged-and-dropped them from iTunes to the SD card (Mac).
Have sent an email to B&O customer service - let's se if they can cast some light on this. Will post here if useful info from them.
Thanks for your input.
Are these downloaded MP3's or something you have encodec yourself - if so, what did you use to encode them?
Hi, I encode them myself from CD's using iTunes (I have a Mac computer if that makes a difference). I have just ordered a conventional slow speed 2GB SD card of the brand SanDisk which I understand B&O recommends so will se if it makes a difference.
I have 2 BS3's and I don't recall either making a hiss noise like you describe. 🙁  I've used many different sized cards and speeds over the years.  I would guess it needs a repair, or (if repair costs are similar to other B&O costs) learn to deal with it 🙂
Stan
