Good evening.
A short while ago I became the owner of an old BeoSound 2300. 🤩. Great looks and even better sound in combination with the BeoLab 2500 speakers.
The doors are showing a small gap. I found a tutorial on this site (/forum/imported-unmapped/annoying-gap) to fix this. The only problem I am having is, that after removing the 7 screws on the back, I am not able to remove the rear cover. I am reluctant to use to much force. Does the cover slide upwards, or just straight backwards?
Perhaps somebody can give me some advise. Thanks.
Mark
