Beosound 2 review: Hmm
OK there is nothing wrong with the BS2, it has been compared with another BS2, and also an iPod, and the sounds was totally identical. Including the white noise i hear. I must have super hearing, because i seem to be the only one with these complaints. My partner actually reckons i have an insensitivity to lower frequencies, how is that possible?? I must percieve sound differently to others. The sound from a BS2 in undoubtedly clear and accurate however. Should i apply for a job on the listening panel?? 😎
i really understand what you did talk about, but i know it's present, it does not mean I hate it. I really feel the so called "white noise" and "lack of bass" is acceptable in my standard.
As you said, its sound is great for some other areas
A job on the Listening Panel would be probably the best job in all of Bang & Olufsen... If you really want this, there is no reason that you couldn't do it.
I'd be jealous.... 😜
I'm only 20, and live in Australia, but wouldn't know how to apply for such a job!
I'm sure it's not as glamorous as is sounds, i assume it still requires dedication and hard work like most occupations. 😕
