Beosound 2 problems with 2GB SD Card
Got my Beosound 2 today. However, it seems to have a problem with my Panasonic 2GB SD Card. So, I updated the firmware but the problem persist. With a 64MB card it works without any problems. And ideas?
Thanks!
Matthias
It mosn't be a high speed sd card! filse has to be placed in a folder (no sub folders in a folder) any help?
Try reformatting the SD card to FAT32 as it may be preformatted to NTFS which BeoSound 2 may not be able to read from. Ensure that you are copying mp3 or wma sound files only. Let us know how you get on.
Simon.
the user manual says:
Fente de lecture pour carte SD
• Carte SD (1 Go) • Carte multimédia (128 Mo)
• Carte miniSD. (512 Mo)
. (512 Mo)
Fente de lecture pour carte PC
• Carte SD (1 Go) • Carte miniSD. (512 Mo)
• Carte multimédia (128 Mo) • Carte Compact Flash (1 Go)
• Carte Smart Media (128 Mo) • Memory Stick (128 Mo)
• Carte xD Picture (512 Mo) • Carte Flash ATA (128 Mo)
• Memory Stick Pro (1 Go)
Un adaptateur de carte PC standard est nécessaire pour
pouvoir utiliser ces cartes.
(Certains adaptateurs de carte PC ne sont pas compatibles.)
. (512 Mo)
What kind of problems ?
did you use beoplayer to put music on the card or drag and drop directly ont the card?
did you press the two bottom arrow key to update the catalog ?
I use a no name sd card on my bs2 without problems.
Just got it running. I draged and dropped via the normal explorer. So, I guess I had to press the lower two triangles to update the playlist. The update takes some times and I have the impression that each updated folder is confirmed by a short "beep".
Now it works fine, also with my 2GB card.
Thanks again!
Matthias
