Beosound 2 Louis vuitton case
hello,
on the case i have one question the beosound 2 does not fit well - i mean the entire rubber pad with controls does not seat very well.
aint sure if it has got to do with  craftsmanship.  alternatively can i check if this genuine or 1st class imitation?!
the button for fastening the upper flap seems to be different in the media centre files of B&o (google Beosound2 Backgrounder) will take you through the PDF link -- i am finding difficult to embed the link here
FYI - i recently picked this on e-bay
regards
pattabhi
hello,
reposting as i am bit anxious on this one.
thanks very much indeed for your feedback
regards
pattabhi
No feedback other than the liklihood of this being a fake has to be astronomically slim. What a strange and useless thing to rip off.
In all my years as a BeoSound 2 fan I never actually saw one in person so who knows why it won't seat properly.
very well would your reaction change to --- "first quality imitation" !? when you compare it with this one ....
Probably overtime the leather has changed shape. This is very common with leather, look at everybody's wallets!
