Think I found the answer to my questions from the other topic 'Roon' - thanks a lot @Ulrike
Essence: need a DAC rather than a streamer since BS2 has only analog in (!)
From @Ulrike
Regarding your question, it depends.
The BS2 has neither a digital nor a usb, only an analog via cinch mini jack input, unfortunately.
So it is not possible to feed a digital signal like RAAT from a Roon Bridge via Spdif, which is then processed by the DAC of the BS2 and played back. With many other speakers no problem, just connect a Roon Bridge, e.g. a Raspberry Pi with a HAT, via spdif or optical out to a speaker, then the internal dac of the speaker processes the RAAT signal.
So for the BS2, or the A6 as well, you need an external DAC, because it only accepts analog signals.
I tried all day yesterday, rearranged and compared, and have now completely switched everything in the house from Chromecast to RAAT. Next I have set up different zones for Roon, which is no issue with Roon Ready devices, which now play in perfect sync quite like Chromecast groups.
I have a Bluesound Node 2i, to which now the BS2 is connected as well as a TV via optical for Roon.
I made a comparison - an older but quite good Denon DAC with the same cable on the BS2 sounded better than the Node, the DAC is obviously crucial here for the sound.
Everything is now arranged in such a way that Chromecast can still be used as a fallback if necessary. Who knows ... :)
