Beosound 1 flashing rapid red
Hi all! My BS1 is flashing rapid red and trying the reg stuff as updating, cutting power chord😁, etc doesn’t help.
Anyone else in this situation?
Any ideas beside taking it to the dealer?
Was in same situation unfortnally the only solution was taking it to te dealer. He send de Beosound 1 back to factory and they replace the motherbord.
I had that problems occasionally. Most times I have been able to power cycle the unit and it was okay after restoring again.
liviu_o wrote:
Hi all! My BS1 is flashing rapid red and trying the reg stuff as updating, cutting power chord , etc doesn’t help.
Liviu_o,
How did you go?
Did it work itself out? Or Did you take it in?
If I recall mine flashed red when I was connecting it back to a new network. Have you tried the setup button underneath and try to set it up from scratch again?
My Gen 1 BS2 did this a while ago, connecting it via cable to the router when setting it up again did the trick. Give that a try.
