Beosound 1 discontinued?
I'm a very happy BS1 owner... and find it sad to see it being discontinued.  The looks and sound of this sculpture keep on amazing me! But.. time and technology keep on evolving ...
@Alex;
Agreed, the Beosound 5 is a very good design, I think Mr Hermansen does his job well. His A8 headset also is a much copied masterpiece.
Nevertheless I think the beocom 5 will prove to be a mistake, has nothing B&o to it, for shure isn't going to be a classic design, it simply doesn't stand out of the majority of phones on the market. A much cheaper Siemens DECT phone is a better design.
Well I suppose that couldn't keep selling it forever but it was certainately a very good product. Obviously it wasn't meant as a main system but perfect for a spot where you needed some music.
Too bad, I really like the Beosound 1.
I can´t understand why B&O don´t update the BS1. MP3 Cd-Player and SD-Card socket or maybe socket for an Ipod instead of the CD-Player and they could sell much more BS 1 in future!
I agree.
I have two Bsnd 1's and they are used daily - one mainly for Radio 4 ( speech based UK radi ) and the sound is superb.
Truth is, it should have been updated for CD/mp3 capability years ago  and adding a USB/SD input can't be beyond those clever Danes - given every £80 bit of plastic crap has one built in, they can't be too costly.
Better still - why not just replace the CD mech with an ipod dock.
Look at this - http://www.sonos.co.uk/products/zoneplayers/s5/default.aspx?rdr=true&LangType=2057
Doesn't sound (quite) as good.  But there's a lot of tech in there. Half the size.  One third the price.
Importantly - it suggests the basic form is appealing and saleable.
Its a shame... but when BSnd 1 launched it was £590 - it's now about twice that - so perhaps it is inevitable.
I smell a project!
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
Beofan2 wrote:
but what about BS7??? the BS between BS6 and BS8.
When Bang & Olufsen are thinking up an idea (in idea land) they have to put aside the next number (ie BS7).  If they do not deside to make that product or idea, they can not use that number again.  Which is also why BeoSound 5 came out after BeoSound 6 because the BeoSound 5 was being thought up before BeoSound 6 came out.
Hope that clears it up!
Seems awfully "mathematical" (IF>THEN).
I hope they're a tad less rigid in their development than what you say. Being Danes, I highly doubt they're acting like old school Soviets.
Too simple. You want a solution where you have to move the music from your iPod to a separate storage disk, and then manually enter all the song info using the Beo4 without a display showing you what you are writing. Then you're talking!
