Got it working! Had to do a factory reset.
Queetions. Now it just says “null” on my Beoremote. Can I change that?Couldnt get My Button options to work under the app. Anyone had any luck?
Hello,I‘ve tried it with my Beoplay M3 and the Beoremote BT works with the M3. The M3 got a MyButtons configurationpage
That is new to me - did that change after a recent update?
Could you post a picture of how this configuration page looks like, please?
Nice - and how about the MyButtons?
@Razlaw
in that case you will have to switch to the device that you want to control in the List of the BROne.
Thanks!@Razlaw in that case you will have to switch to the device that you want to control in the List of the BROne. MM There is a tv - and there is a BV.
