Beoremote One: Can I connect to LG OLED TV?
Hi Millemissen,
I have seen a danish authorised seller sell an "upgrade" to a Beovision 7 floor stand with a Beolab 7 speaker.
They simply add on a LG C9 to the floor stand with a adapter bracket, and it should then work with the Beolab 7 speaker.
They also sell an upgrade to a B&O remote so it can control the tv.
If the BS Stage is controlling the LG C9, how can this be possible, since this setup is without af BS Stage?
Looking forward to hear, since I am really hoping the BeoRemote can work with the tv alone.
Any updates on this?
Has anyone tried to pair a BeoRemote One directly to a LG television via bluetooth (like you could do directly to the Apple TV?). I am also very curious whether this would work.
The Stage isn’t really an option as it doesn’t allow for surround sound but if you can pair the BeoRemote One directly to the LG and also get an Axiim Link to offer surround sound to Wisa speakers it suddenly becomes a complete surround sound system with the BfO remote.
It doesn't. It only works via the Stage, which is connected via LAN to your LG TV. And even then it's not the same as using the BeoRemote with the Eclipse. No PUC control, so you can't access some external boxes such a Sky Q.
