BeoRemote One - availability??
The Beo4 (navi) can be used for the Avant!
Just received the response from BeoCare - took less than 2 hours 🤒
They confirm that it can be used - but they of cource recommend the BeoRemote One in order to have 'all the functions' working. ("for at få fuld udnytte af alle funktioner.")
That is not a problem because you can name your sources your self. So if you have a playstation 5 in 2020 you will be able to name it on the remote your self. And the TV will download the code from the internet.
They confirm that it can be used - but they of cource recommend the BeoRemote One in order to have 'all the functions' working. (" for at få fuld udnytte af alle funktioner. ")
Hi MM,
that response was to be expected.
But do you have to tell the Avant if you will use a Beo4 with or without navi button (at older Pre-BSys4 based TVs you have to store this in setup menu). And what has to be stored at these TVs if you wonna use a BeoRemote One: Beo4 with or without navi button?
Greets
Räuber
The userguide says nothing about this, we will have to look for ourselves in the shop.
Unless somebody already know the answer.
My dealer told me that the BeoRemote One (steel finish) will be available in early July for purchase without the Avant.
Currently the 3 MyButtons do only work with the Avant. My dealer spoke with Struer and asked if they will also work with the BV11 in the future, but he did not receive a definite answer. :(
double post
My dealer also told me this lunchtime the remote will be available as a standalone purchase from June/July, so looks like it will be sooner rather than later.
Bad news though if the "MyButtons" won't work with the BV11 etc. You'd have thought it just be a software update.
In Beo4 mode, they'll work as standard source buttons you can configure.
I was told that it is just a software update, but that Struer hasn't decided yet if they want to have the functionality for the other TVs as well. Maybe they want to keep the Avant somewhat exclusive... 😮
Given it's going to be the standard remote, I cannot see how they can issue a remote that has three buttons that have no function on all but one TV. I am sure they'll update Beosytem 4 based TVs, otherwise that wouldn't make sense.
