Beoremote Halo, the future B&O remote control
Doc,
Since the Avant isn't actually supported by the Halo (yet) but the Core is, can you add the Avant as the primary linked product to the Core and add the NL/ML Converter as the secondary linked product to the Halo and get it to work that way? Both of my integrated BeoVision setups involve a Moment, which isn't supported by the Halo, so I don't know if the Core still shows up as a product on the Halo when used in an integrated setup. You'll still want to follow my 2-steps when making any changes. I went for months scratching my head trying to figure out why my second beogram turntable wasn't appearing as a source on  BeoRemote One for bluetooth devices in my NL system.
Carolpa wrote:
Audio wrote:
I have a compatibility question regarding Beosound 35?
Is somebody able to test, if the new BeoRemote Halo is showing the meta-data (e.g. title name, album name) when streaming via Airplay to a Beosound 35?
(as expected) only "Airplay" is displayed on the Halo
Do I understand this correctly? With the Beoremote Halo I can only change the volume on the Beosound 35?
Same functions as a Beoremote Essence offers?
So no need of the display of the Beoremote Halo?
mm08642 wrote:
Do I understand this correctly? With the Beoremote Halo I can only change the volume on the Beosound 35? Same functions as a Beoremote Essence offers? So no need of the display of the Beoremote Halo?
if you use a DLNA media server and you tagged your files, the tag info is visible on the Halo. Same when you upnp/DLNA stream music to the BS35.
You will get no tag info on the Halo when you AirPlay to the BS35. Note: same as the info on the BS35!
Thank you very much for the fast feedback.
It's a pity that B&O can't manage to display the meta data of an Airplay stream with the Beoremote Halo. Unfortunately, no reason to invest in a Halo for me. Too bad.
In my case I have several B&O speaker systems now, all either connected to a Core with Essence Remote or having the inbuilt B&O streaming technology. For me the Halo would have been a perfect product since I am all in on the B&O audio ecosystem. My current set up is to use 2x Essence remotes (which I have really grown to like) and an iPhone SE that is basically only running the B&O, Music and home automation apps. At $399, it is half the cost of the Halo, aluminum and glass with wireless charging but missing the amazing volume control of the Halo. But the Lock Screen shows the card of what is playing on any speaker...at $399 I would buy the Halo in a heartbeat. So it comes down to cost/value to me...
Can literally ANYONE explain to me why it is better to get this thing vs:
Any old iPod touch that's basically free and will do the same thing.
An iPad Pro and fancy desk stand and still come out cheaper.
I really can't make sense of this thing.
BeoLab 18's. Beolab 3's. A8. A9. A2. H7.
`I guess those who dont want a phone or tablet are sympathetic to the Halo.
And i would really like a dedicated Halo like device to handle the music experience
Unfortunately the Halo does far far too little, outside of look floaty and nice i guess.
Allegedly functionality will improve with updates, but history would suggest that those will be slow to arrive, offer few improvements and fall well short of a fully fledged music controller.
I am still tempted to buy the Halo, for me it has a wow factor over any dedicated phone / tablet solution (and yes that would be a rational better choice).
The things I like:
- It’s a remote (volume controller) that doesn’t look like one
- The rotary dial, like on BS1 , the physical touch and response.
Because it looks better than any alternative.
I like the Halo as its simple and my wife likes it as well. Can anybody let me know if 1.1.2824 is the latest firmware? Also if any of you can store more than one Deezer playlist as I somehow cannot whereas I can for TuneIn stations...
