Beoremote Halo, the future B&O remote control
Wolf_70 wrote:
I've just set up my new HALO and I've got two problems now:
- the software updated is shown in the App (red light), but I cannot start the update in the app (the button is light gray (currently: 1.0.2635)
- the multiroom button (double window) for touch to join is not shown in the HALO (only the four favorite symbols are shown)
I appreciate any support, Wolfgang
1. Goto settings, products, beoremote halo, software in the B&o app. There it should be possible.
2. Visible after update
that's the problem; in the app under software the update button dosen't work (it is light grey and nothing happens when I press the button)!?
were do you see the greyed out button?
If you go to Beoremote Halo and there to software; there I had the same issue. But see my description; there I could update the Halo
in the B&O App (iPad)!?
goto the icon next to the "+"; the "man" (or is it an imbalance) = Settings
than to Products; Halo; Software
Thanks for your support, Carolpa!
But this is exactly what I have done. My new theory is, that the update is running in the background and I simply have to wait. I will give a feedback!
I am having exactly the same problem with a Halo I received yesterday: red dot indicating software update, grayed out update button, and no multiroom icon.
I have submitted a support case.  I expect B&O will acknowledge receipt of the inquiry, wait a few days to tell me it has been raised to a higher level, and then never respond to me again.  😕
2x Beosound Moment 4x Beosound Essence Mk II 3x Beolab 8000 1x Beolab 6000 1x Beolab 3 3x Beolab 2 4x BeoPlay M5 1x BeoPlay A6 9x Essence Remote
I read about the link icon after unpacking. It didn't show.Then I saw an update was due....... tried to pull the update, had a greyed out button. But within 3 hour the Halo was up and running with the latest sw.
So no havoc, just little patience (which I didn't have.......)
HALOlujah
Update was installed over night! I connected it to the power supply in a strong WLAN area. Then over night the update was installed to the lastest software was installed (1.1.2890).
