BeoRemote Halo and Beovision Horizon
Helo, has anybody already successfully paired the Halo with the Beovision Horizon? I can check the checkbox in the B&O-App, but then I get an Error Message, that the Product could not be added :(
Thanks for your help
yes
And one can control the Horizon
edit: in standby I also do get a message that the Horizon is not reachable/available on the network. Presumably solved with the Horizon settings.
Carolpa wrote:
yes
Tadaa … new year and it works … great
Ok, now i have paired the Horizon successfully, but the Halo can’t wake it up. The Beo-app is capable of waking the tv up but not the halo. Any ideas?
Strange! If the app can the Halo should also be capable.
Wake on WLAN is set to ON? (settings/wireless & networks/wired or wireless)
