Beoremote App
Does anyone have any idea how to make the app find the TV?
They are patently on the same network, as I have but one router. Obviously the iPhone is Wifi and the Avant is wired, but they both have internet connectivity, and an iNet scan on the phone shows the Avant..
Thoughts?
Hooray that B&O have finally seen sense and made the app iPhone compatible. Used it twice on an iPad and went back to using the Beo4.
Boo that it doesn't seem to work!
"No Bang & Olufsen products detected on this network" Stays stuck with that message.
Hey ho.
Be sure that the tv is set to 'wake on LAN' - the power saving option must be turned off.
P.S.. How many BeoRemote app threads do we need - there already are a couple of them on the forum !!!
And I thought it was just me, or my malingering Avant!
The TV is on, shouldn't that be sufficient?
And, apologies, I posted it about 30 seconds after I got the email promoting the iPhone version, didnt realise I was late to the party...
Try closing the App completely. Pressing the Home button isn't enough, you need to Double-Tap the Home button and slide up the Beo-App.
That solved the problem for me.
Did that.
Also forced a reboot of the iPhone, and a power off restart of the Avant, and the router..
What software version does your TV have? You need the very latest version that was made available on Monday.
Yes, it auto updated on Monday ..
1.0.8.36550
and it says 'No new updates' when I check.
to see whether there is a problem on you network configuration you can do the following:
- download a Bonjour/Zeroconf scanner from AppStore e.g.
