Beoremote app for Iphone, can't find my 55"Avant
Hi all. Do someone know what can be wrong?
Iphone 6 IOS9.1
Newest Beoremote apps
TV connected with fast IP adress, and with RJ45 cable
Router Tilgin 2301
Apps do not find any Bang and Olufsen on the network. :-(
TV is ON
WIFI name PH and password only digit
What can be wrong?
Per
Beo remote can't find our TV on one of our iPads .
Have you enabled wake up on W/LAN?
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8 , MX 5500 . Beolit 15 , Form 2i , Beolab 2000
Is the TV activated in the app on your iPad? Press 2 seconds on your screen when you see your different products in the main menu of the app
I don't remember deactivating it but I did and it works. Thanks
now to increase the display time setting for spotify use...
Hi
Yes it is enablet
Yes it is, I can download go on facebook etc.
Yes
Yes 100% sure :-)
You can activate products on the app as per sugestion, this is what it looks like.
