Beoport n.radio web access no longer available
Looks like they are confirming they are working on it / fixed it :
Dear Nigel,
Thank you for your patience.
Our technicians can confirm that they are working on a resolution to your lack of internet radio. This should be resolved already, and if not within 24 hours.
Should you require further assistance, please do not hesitate to contact us again.
Kind regards,
Marti
Bang & Olufsen Support
I heard back from beocare this morning to say they have been working on resolving the issue and it should now be fixed :) I am at work so won't be able to check mine until this evening, but it looks like the domain name has been restored. Rob.
Hi Frog, Is N.radio all working on your beoport now? I could see the stations in the windows app, but could only get BBC radio 1 to play. Other bbc stations and absolute radio didn't load. Cheers, Rob.
Actually, I have 4 Beosound 5s and no Beoport. All working though. Odd you are only getting one station though!
Hi Alfio,
Are your N.radio stations streaming for you on your PC using the beoport software?
Many thanks.
Rob.
alfio wrote:
Dear All
as  announced the N.Radio support ( used by beoport) via the http://nradio.beoplayer.com/nradiodata.asp is no longer  available the domain has been dropped.
I was wondering is it could be possible to emulate it  in order to connect to the many free radio available on the web.
I do not know the detail of the interface apart from the registry information that identify the web site and an id.
[HKEY_CURRENT_USER\Software\Bang & Olufsen\BeoPlayer\N.Radio]
"ViewSelection"=hex:00,01,02,03,04
"BufferTime"=dword:00000005
"ServerURL"="http://nradio.beoplayer.com/nradiodata.asp"
"UserId"="60B1D8994C224AC69B91931AE710521A"
"SoundIcons"=dword:00000001
"EnableDebug"=dword:00000000
Regards
Hi
unfortunately I am far from home until saturday.
So I can not check until then.
Regards
Hi
I checked this morning and tested few radio and they seems to work without problems.
So I confirm that the problem has been solved.
Thanks for checking. It could just be that I checked it too soon after the services were restored. They did say up to 24hrs. I may try out BM-Link on the Mac instead... it would allow me to add in additional radio stations to N.Radio via iTunes that are not listed in the Beoport app.
alfio wrote:
Hi
