Beoport n.radio web access no longer available
Thanks, the more that do, the likely it will be fixed.
As an aside, what would be a simple addition (not replacement) if they don’t fix this? I was using it to listen to radio stations in a different country. I’d ideally like it to be activated on pressing the Radio button (like it does with the Beosound 5) and I have an all-ML setup.
Hi
 as Kimhav mentioned it woudl be enough to get the script used by B&O to simply emulate an interface over a small pc / a raspberry Pi  to interface the existing web radio.
Regards
Yes, I know that as it was mentioned. I was asking about what other device would do the job.
Maybe it has to do with an update to the firmware.
In case of Beoport this is the setup after last version available and even supported by BEOCARE with the updated registry information.
For sure netradio is working on my Beovision Avant 55 so the server address are diffrent between BEOPORT and BV Avant 55.
Regards
Hallo
could you please check the following Registry then?
HKEY_CURRENT_USER\Software\Bang & Olufsen\BeoPlayer\N.Radio
regards
For my Beosound 5s, I have the same registry entry as you do for your beoport.
Hi
Very interesting, I just checked the url ( from my pc) and with my surprise, I did not get anymore the "domain could be recollected" banner, but some dataflow. I cannot chexknif my Beoport works because I am far from home until end if week. Could be that B&O reacted to the request at their technical support. Regards
Alfio
Almost certainly they have responded to my request but they have yet to tell me!
There is also a discussion in the Beosound 5 forum of Beosound 5s not connecting to the domain. My BS 5 was not connecting. Today it is once again connecting. Perhaps Beoport NetRadio is also once again connecting?
