Beoplay warranty service.
Wow, so I'm lucky on this one then.Of course the cover can be glued but what a mess if you want to take it off to change a tweeter or battery !I had exactly the same issue and it was sent back to me as non repairable/swappable, so I was a little unhappy. I managed to prize the plastic clips back and refit the the top, you can't even purchase the tops as an accessory now!
Only have great experience with B&O. I head a pair of H6's that came with a loose connection. The (non-B&O) dealer refused to replace them, and let me know that there was nothing they could do due to "B&O policy".
Well I complained to B&O and they promptly called the dealer and gave him a stern talking-to, after which he sheepishly called me up and let me know that I could come around and pick up a replacement pair whenever I wanted.
Problem solved AND justice served 😁
I find the quality of the leather bad compared to my previous model but the quality of the buttons better.
Speaking of 'the leather strap'.
If that is broken, can you replace it yourself - and how?
Anyone had that problem already?
Probably not an issue for a 'warranty replacement' ;-)
It appears to be a strip of leather threaded through a hole and tied in a knot. It should be doable.Speaking of 'the leather strap'. If that is broken, can you replace it yourself - and how? Anyone had that problem already? Probably not an issue for a 'warranty replacement' ;-) MM There is a tv - and there is a BV.
I just stated that I find the quality of the leather strap not as good as the previous one.I had a soft dark brown strap now it's a hard clear brown strap.
No big deal at all it will stay like that.
Maybe their financial controlling showed them where Beoplay can save a few cents on every product... but didn't think or care about the lowered quality perception of the customer. ;-)
According to all the positive reviews the Beoplay H6 and the A1 are such a success for Bang & Olufsen... how can you dare to lower the quality of such products? That wouldn't be a very clever move.
