Beoplay V1 wall bracket - change in turning position
Dear Moderators (and beoaus),
I have two pdfs for the Beoplay V1 wall brackets:
- One for Type numbers 4726 / 4737
- One for Type numbers 4752 / 4753
I’m happy to submit them for inclusion in the Beoworld User Guide library if you tell me where to send them. They’re no longer on the B&O zendesk site, as far as I can see.
Lawrence
Are you saying you switched it from the right to the left? I need to know how you got the mount off the bar
The wall bracket is reversible, I’ve done it with my own. You need to take it apart at the hinges and switch the poles top / bottom so that fit in the body of the TV correctly.
James is correct. I have taken photographs but unable to attach them using my iPad Pro or my iPhone X. If you need any further assistance let me know. You may be able to view the photos I have taken and uploaded of my V1-32 by clicking on my username so try that too.
Assuming you can see the photos (or even if you can’t) please note the holes either side on the underside on the television. You place a screwdriver inside these and press lightly on a button that will release the poles, which you then slide out. You may wish to use a torch to peer trough the holes so you can locate and see the release buttons beforehand.
Adjust the bracket/hinges to the side you want to use and reinsert the poles. These will automatically click in place. Be careful not to slide the poles in too quickly or they will go too far. You will then have to pull hard (very hard) to get them out, which is a cumbersome task.
The screwdriver pushed into the holes is only used for releasing the poles and it is easier if you have 2 people so you can both do a hole at the same time. It is still possible for 1 person to do it, just a little trickier.
All the best,
Simon.
