I want to get a Beoplay V1 40....
As front speakers I want to use my Beolab 8000 (connection available ??)
For rear speakers I would need a wireless type to avoid the cables ???
Thank you for suggestions.
Hi Hans JΓΆrg,
what - exactly - is your question π
If there is a question π³
My questions are
- are there connections for Beolab 8000 available (should be my front speakers9
- for rear speakers I need a wireless solution
the whole thing should end up in a "surround" setup
The V1-40 has 3 PowerLink ports - each with two outputs.
Means you can connect up to 5 speakers.
If you use the internal speaker(s) as a center, you can built a 5.1 system with ease.
If you need wireless connections (for your rears), you will have to buy the optional IWS Transmitter, since the V1 does not have wireless speaker connection built-in.
If you choose newer (WiSA compatible) speakers for rears, you are good to go then - if you use older BeoLab's, you will have to buy the wireless receivers too.
Gruss MM
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
